Help with Runtime error '9': Subscript out of range.
Hi there,
I am new to VB and I was given a task to look at this little VB program which was written by other programmer.  It was strange that I was able to open it and created an EXE on one machine before but now I keep getting this runtime error.  Attach is the code.
Any help is appreciated
Private Sub LoadArrayPolls()
    ' Load the Document Types and related symbols into an array and then populate a combo box
    Dim PollStr As String
    Dim Indexcount As Integer               ' Counter to load the ListBox
    Dim Arraycount As Integer               ' Counter to load the ListBox
    Dim NumberPollFile As Integer           ' File number assigned
    Dim PollNo As Integer
    Dim NumberofRaces As Integer            ' Number of Races in this Polling Station
    Dim RaceNo1 As Integer
    Dim RaceNo2 As Integer
    Dim RaceNo3 As Integer
    Dim RaceNo4 As Integer
    Dim RaceNo5 As Integer
    'Dim RaceNo6 As Integer
    ' Retrieve a free file number
    NumberPollFile = FreeFile
    ' Assemble the string for the Poll station information file which includes the subdirectory paths
    PollStr = ELECTIONDRIVE & ELECTION2001DIR & DATADIR & CONFIGURATIONDIR & POLLSTATIONFILE
    ' Open the Polling Station text file containing the races to read into the Poll array
    Open PollStr For Input Access Read Shared As #NumberPollFile
    ' Initialize Array Counter
    Arraycount = 0
    Do Until EOF(NumberPollFile)
        ' Read the Poll Number and the Races from the Poll file
        Input #NumberPollFile, PollNo, NumberofRaces, RaceNo1, RaceNo2, RaceNo3, RaceNo4, RaceNo5
        ' Store the information into the Poll array
        ' Store Poll number in array
        ArrayPolls(Arraycount, 0) = PollNo
        ' Store Number of Races for this Polling Station in array
        ArrayPolls(Arraycount, 1) = NumberofRaces
        ' Store Race1 number in array
        ArrayPolls(Arraycount, 2) = RaceNo1
        ' Store Race2 number in array
        ArrayPolls(Arraycount, 3) = RaceNo2
        ' Store Race3 number in array
        ArrayPolls(Arraycount, 4) = RaceNo3
        ' Store Race4 number in array
        ArrayPolls(Arraycount, 5) = RaceNo4
        ' Store Race5 number in array
        ArrayPolls(Arraycount, 6) = RaceNo5
        ' Store Race6 number in array
        'ArrayPolls(Arraycount, 7) = RaceNo6
        ' Increment the counter
        Arraycount = Arraycount + 1
    Loop
    ' Close the file
    Close #NumberPollFile
    For Indexcount = 0 To (Arraycount - 1)
        frmPoll_Station.lstPollNumber.AddItem ArrayPolls(Indexcount, 0)
    Next Indexcount
    If Arraycount > 0 Then
        frmPoll_Station.lstPollNumber.Selected(0) = True
    End If
End Sub
RE: Help with Runtime error '9': Subscript out of range.
Which line is erroring out?  That error means that you've tried to access an element of an array, list box, etc. that's outside its limits.  For example, trying to access element -1, or element 6 of a 5 member array.
ArrayPolls(Arraycount, 0) = PollNo.  This line gives me error.
I declared the Const NUMOFPOLLS As Integer = 206 to read the ArrayPolls
Dim ArrayPolls(NUMOFPOLLS, NUMOFRACEINFOCOL) As String.
I may have to look into the text file for the array.
Sorry, did not have a chance to reply until today.  I found out what the problem was.  I changed the path to point to C:\
Thanks for the help guys.
