Designing Lateral Beams
I've been modelling a steel frame building with moment connected beams acting as the lateral system. When I run the program with the auto select list and run a steel design, I get the largest member in the auto select list assigned to the lateral beams. I tried removing that member size from the list, and rerunning the analysis and design, only to get the next largest member. Checking the strength and deflection ratios of the member, I am well below the limit for failure.
Does anyone know why the program isn't designing the beams appropriately, is there something i need to check with the overwrites. Any help would be greatly appreciated.
RE: Designing Lateral Beams
try this
http://www.csiberkeley.com/faq_ETABS.html#sfdo4
