what does'Trust plate' mean?
When I read a paper about auto materials,they mentioned an auto part 'trust plate and tension struts' can be made of that material. I dont know what does 'trust plate'mean.Is that mean 'safty belt plate'? Also can we say ' safty belt' as'trust belt'? Thanks a lot.
RE: what does'Trust plate' mean?
I believe that the word should have been "truss" not "trust".  A truss is an engineering term for a 2-dimensional or 3-dimensional structure that features various members (beams, struts, etc.) connected at nodes, and the whole structure being fully constrained.  Look at any engineering statics book for more information.
I agree truss plate, but not sure about automotive application. Truss plates are used in civil engineering to connect to members, generally two 2x4's or more at one seam. It is a sheet metal plate with many pierced holes, whose pierced material is intentionally left sharp and protruding out of one side. Then the "seam" of members joined together with a series of miter cuts, and the trus plate is pounded into all of them, making one fixed truss joint.
Hope this helps, but not relating to auto sorry
I also agree with GregLocock that it should be a thrust plate, since it is an automotive application.
It certainly struck me as meaning "thrust plate".
Some of the Asian scholars have tended to mis-pronounce 'thrust' as 'truss', & this has probably carried over. There are a few other quaint ones. :)
Des Aubery...
(adTherm Technology - www.adthermtech.com )
