Will an LCD be damaged in a vacuum oof less than 10 Torr?
Hi Everyone,
I would like to know if anyone has any experience with anything with an LCD display being exposed to a vacuum environment of between 5-8 Torr.
Let me know if it can survive please.
Scott
Scott
In a hundred years, it isn't going to matter anyway.
RE: Will an LCD be damaged in a vacuum oof less than 10 Torr?
It is a liquid after all. Barely sandwiched inside very very thin glass. It would probably bulge and quit working before actually exploding. Not sure. You want to send me one, I'll test the theory for you. Anything that has a running display would work. That way I can see if it quits working thru my clear vacuum chamber. I actually have nothing I can do that to presently.
I can no-way get clear down to <10 Torr but, if there is going to be problems, it will be well before that.
Keith Cress
Dan - Owner
http://www.Hi-TecDesigns.com
Dan,
That is exactly how I plan to test it. I just figured if somebody already had....well, saves me an LCD...
Thanks again,
Scott
I see no problem with a smaller passive LCD in a vacuum. Slight swelling of the fluid may cause bi-refringement issues (rainbow-color as the glass spacing varies) but the LCD should still work.
However, I don't know enough about the larger active matrix color LCDS used in cell phones and computers to say anything about them. It could be that the glass-glass spacing is far more critical
It worked out fine.
Scott
Keith Cress
Worked on my cell. Really dont know what pressure I got down to, but I know on the CO2 lasers I used to work on, water was gone by 8 torr. Started to really boil out around 10-11 and then was gone by 8. Really played heck on the vacuum pumps. Lots of oil changes.
Worked on my cell that landed in the dog water dish when I bumped it off the counter opening the toaster oven....I know, I know, not for your home, for your work! It WAS my work cell phone though, and a neat experiment!
Scott
I also discovered what happens when you run a vacuum pump with a seal leak on the chamber door at about 5mm Hg for an hour. It filled then entire building with an oil haze. Dang!
Keith Cress
itsmoked - to remove adhesive, try CRC brake cleaner. It's in a red can found at most auto parts places. I even use it to remove label residue from the front of test equipment, books, and manuals. Drys in a few minutes, leaves no residue or smell. Just don't get it on syrene plastics.
This whole blower is grey plastic... I tried my favorite, methanol, which caused the adhesive,(with a million flegs of foam), to smear around into bigger clumps but it was still very hard to remove. The plastic started to haze and I think come off on the paper towels. Hard to tell as the foam and the plastic and the adhesive are all grey.
I do have a can of CRC brake cleaner about 6 feet from the blower! I will drip a drop somewhere on the housing and see what happens before I commit.
Many thanks for the suggestion. I keep thinking there must be some magic chemical bullet that will do the trick..
I tried soaking it in orange cleaner and Micro, (a strong lab cleaner) with no effect what-so-ever.
Hope the CRC works.
Next stop hot lye??
Thanks.
Keith Cress
