DWG editor
DWG editor
DWG editor
Does anyone know how to apply a surface finish symbol within DWG editor?
RE: DWG editor
Scott:
I do not usually use ACAD but I need to add the symbols in DWG editor. I find no ref. in the help files.
RE: DWG editor
Autocad and Dwgeditor don't have a surface finish annotation like Solidworks. I think most companies use premade blocks...try searching around the net...I'm sure they're some out there.
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP3.1 on WinXP SP2
RE: DWG editor
That makes sense, I will make a block.
Thank you!!!!!
Dan B
Plastic Services Group
