Deleting Old Versions
I was wondering if there is a tool that I can use to delete all old versions in the current working directory. Presently I am deleting old versions one at a time. I was wondering if there is like a purge command.
thanks
RE: Deleting Old Versions
Purge
http://www.profilesmagazine.com/p36/marsalek.html
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
one of the best I found is Spekan Purge Tool. Do a search with google.
-Hora
David,
See the following thread
http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=33676&KW=purge
Speken Purge Tool also recommended here & I think its pretty damn good as well. (I use it at home, but where I work they refuse to load it....they reckon it will conflict with their PDM system....)
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
