write a series of file
Hallo everybody,
I would like to write a series of file where they are different only for the name, like name_1, name_2,name_3 ecc...
what I'm doing is something like this:
do j=1:50
open(unit=2,access='sequential',file='name_'j'.inp',status='old')
end do
how can put the J in the name in order to have a list of file which name is:
name_1.inp
name_2.inp
name_3.inp
name_50.inp
thanks,
Albert
RE: write a series of file
A little trick: write j with I0 format. Remember to close the file after opening it.  I don't know what happens if you open a file and then open another one on the same channel.  It probably stays open but is unreachable and cannot be modified until you close the program.
CODE
   character*32:: filename
   integer:: j
   do j = 1, 50
      write (filename, 10) j
10    format ('name', I0, '.inp')
      open (unit=2, access='sequential', file=filename, status='old')
      close (2)
   enddo
