Proximity of propane tank to electrical equipment?
Where can I find the documentation stating the minimum distance that an above ground propane tank can be from electrical equipment (i.e. motor starter in a factory mounted contol panel on an industrial air compressor/dryer)?
RE: Proximity of propane tank to electrical equipment?
I'm assuming you are talking about an outdoor location. If indoor, the area with propane storage would fall under Article 501.
There may be some additional NFPA requirements I'm not familiar with. You could try searching the NFPA website for "propane".
______________________________________________________________________________
This is normally the space where people post something insightful.
