truck-mounted forklift
i am seeking ideas how to improve the fixation of truck-mounted forklifts on a truck. the existing soultion, where the forks are put into a so-called mounting kit and then further secured by cables, in insatisfactory as it is complicated and security risks arise when not all security standards are fulfilled. Therefore i am seeking a method which makes the mounting more easy, comfortable and secure for the driver. any ideas?
moreover, there are problems with the weight of the forklift, which has negative impacts on the stability during driving, i.e. the distriubution of the weight on the axis is unequal. is there any electronical/mechanical system for distributing the weight more equally?
thanks!
thanks!
RE: truck-mounted forklift
The only possibility is for the truck to have a lift axle in front of the driven axle, a 'cheater' if you will. But this reduces the traction in off-road situations while this axle is down - removing some of the weight from the driven axle. Also this configuration is not legal in some jurisdictions.
Have alook at how they do it overseas....They are far ahead of North America in solving a lot of these issues...http://www.bill-bennett-eng.co.uk/palfinger/bm.asp
