LSIG breakers
LSIG breakers
I am trying to find more info regarding LSIG breakers in general (operation, settings, general theory, etc). Any good web links or books?
thanks.
thanks.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: LSIG breakers
RE: LSIG breakers
I have seen LSIG (Long short instantenous ground) breaker on low voltage system (480V or 600V).
At what service (V and I) they are required (i.e. commonly used) and why?
Are they appropriate for settings, that is can you play with the tripping curves?
Do we have to go with LSIG or LI/LIG breaker would be ok ...or a typical breaker contains all options generally and one would set it up to suit?
thanks.
RE: LSIG breakers
RE: LSIG breakers
I am not trying to touch on that topic. For example, moulded case CB are "fixed" and my question was can you manipulate with setting for LSIG as I am trying to get more understaning of LSIG?
Thanks for the abundant response.
RE: LSIG breakers
http://www.utilityrelay.com/ACProSimProg.htm
