2 volts relay?
2 volts relay?
2 volts relay?
Hi, is there any chance of finding any PCB or plug-in relay working with up to 2.5 volts?
Any suggestions please?
rgds
RE: 2 volts relay?
Over the years I've seen many relays that would reliably pull-in with much less than the specified coil voltage.
In other words, if you don't find a suitable specified product, you might want to try some relays with (for example) 5 or 6 volt coils. To reduce risk, try them at extremes (example: temperature). Also, you'd have to screen them forever in case something changes.
RE: 2 volts relay?
Omron has PCB mount relays with coil voltages of 3 volts with a minimum pickup voltage of 75% of rated voltage.
RE: 2 volts relay?
Hi again and thanks for all the input.
I wish to switcn 12V DC.
rgds
RE: 2 volts relay?
How many amperes ? You may want to consider electronic switch -- solid state relay or some custom circuit.
How many do you need ? any other consideration ?
Space, cost, reliability, etc ?
Is the load inductive -- e.g.motor or solenoid --
or incandescent ?
Please read FAQ240-1032: How to ask a meaningful question
My WEB: <http://geocities.com/nbucska/>
RE: 2 volts relay?
Just be aware that the 75% nominal rating pull-in voltage allows for a selection tolerance but also for temperature. The TC of the copper coil is about +0.4%/degC. Therefore at 70degC coil temperature you lose a significant amount of sensitivity.
Don't consider a reed switch if you intend to switch more than a 50 W (really 50 VA) load.
RE: 2 volts relay?
Amperes and Watts are low (it is a 12V motorbike horn)
I will try some 5 or 6volt coil BUT temperature is expected to rise in the summer...
Any other ideas possibly?
rgds
RE: 2 volts relay?
If you have 12VDC available and you must have a relay for isolation purposes, why not run your 2.5VDC command signal through an optocoupler and use the 12V source to switch its own relay on.
RE: 2 volts relay?
Motorbike theft alarm?
RE: 2 volts relay?
Some modification of a Motorbike theft alarm.
Really complicated to describe here.
Thanks for all help and support, I will go for a 5volt relay and if it doesn't work I will post some thread again...
Cheers
RE: 2 volts relay?
If you have 12V then use it.  These low voltage coils need a lot of current and it is far easier to drive a higher voltage coil.
