Vanadium Coating application to steel
Can someone describe the basic technique used in application of vanadium coating to Steel in the simplest possible way?
What kind of equipment, controls, safety precutions are required ?
How to test if the desired results have been achieved?
RE: Vanadium Coating application to steel
First, it is not really a vanadium coating.  Vanadium carbide forms as a diffusion layer in the near surface layer of the steel.  The general name of the process is TRD (thermo-reactive deposition and diffusion) or just TD (thermal diffusion).  The carbide layer is formed by the chemical combination of carbon atoms in the steel substrate and carbide-forming element atoms (V) in the treating reagent, usually in the form of a molten borax salt bath).  You can find a more information in ASM HANDBOOK Volume 4 Heat Treating or by clicking on the following link:
http://www.tdcoating.com
