Raster view problems in R17 (on x64)
R17 SP04 (64 bit)
Windows XP x64 edition
Intellistation A Pro 6224
4GB RAM / processor (2)
Quadro FX3000 (latest drivers)
I am trying to create an isometric view in raster mode. However, when I attempt to do this, I get a "view cannot be created" error every time.  It does not matter what I set the detail level to - even the lowest custom settings fail.
I'm guessing this must be related to the hardware, as I've created this exact same view in the past on a 32-bit machine.  Anyone have similar experiences?
Thank you.
Catia Design|Catia Design News|Catia V5 blog
RE: Raster view problems in R17 (on x64)
May be you can open a PMR...
Eric N.
I was just thinking I would do that.  There's no way that this isn't a bug or some other unaddressed setup issue.
Had you tried to CATDUA the offending file(s)?
solid7
Am having the same trouble with 32bit version as well...R17SP03
Quote (wofgrrl):
No, because there is no offending file.  This is an equal opportunity error. (at least for me)
I have submitted a PMR.
