Laterally braced beam
I have to design a lintel 40 feet long. It will be supporting 12" solid cmu wall above so top flanges will be embed. Is it laterally supported or not. I think not.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Laterally braced beam
For example, if there's a lower diaphragm, the wall might be stiff enough out of plane to provide bracing.
The 13th Ed. Spec. Appendix 6 provides ways to determine if a beam is braced against twist or compression flange lateral translation--prove one or the other or both.
Depending on the details of your situation, you might be able to show that it's braced. Of course it requires plenty of judgment.
