Steel Grades in France
Does anyone know the typical steel grades in France?
I have a HEB160 and a 200x200x10 tube that I need to check and I dont know what the common stress grades (Fy) are for these.
Any help would be appreciated.
RE: Steel Grades in France
looks like an HSS type section... might try a CIDECT website... don't have my catalogue here, else I'd look it up...
Dik
You will probably get a better answer, but every culture seems to have their own verision of a burrito and A36 steel.
Joe Tank
A 200 x 200 x 10 is a Square Hollow Section.
A HEB 160 is a european wide flange beam (basically a column section).
Not sure about France but in the UK these come with a yield stress of 275MPa, 355MPa, or 460MPa for normal structural purposes.
We are all (Europe) moving to the Eurocodes so I checked EN 1993.  The British version (in english strangely) also has the same values given above.
I think the old French code was NFA 35-501.  In this document the equivalent to grade S275 was E-28, S355 was E-36.
Not sure if this helps though.
http://www.corusconstruction.com/en/design_and_innovation/structural_design/the_blue_book/section_properties/overseas_shapes/he/
Thanks for your help everyone.
I found out that both the tube and the I-beam are S235 (235MPa) which is 34.08 ksi so there is steel weaker than A36!
A6 is the common steel grade used on pre-war buildings, has yield of 33 ksi.
civilperson,
ASTM A6 is a material supply standard that addresses tolerances, strightness, etc.  I think you might have meant ASTM A7.
Joe Tank
