help on reg code
help on reg code
help on reg code
my comp crashed lost registration code all i have left is autocad 2002 trial how can i reboot it to full version
RE: help on reg code
If you did not record your registration details,ring autodesk and request them again.
sc
Acad 2002 stores the registration information on the local hard drive in a file called "RegInfo?????.html" Do a search for this file, then when you find it, open it and you will have all of the required information. The question marks "?????" are the version of AutoCAD you are using. For example if you are using ADT the file name would be: RegInfoARCHDESK.html .
HI , i hope you can help me , I am not being able to change the spacing of my hatching which i use to do in the window for properties. oh, using AutoCAD 2000.  tons of thanks, Marc
Marc,
You can normally change the spacing by setting the scale for the hatch pattern, assuming you are using a standard predefined pattern.  Can you find the scale factor setting in the properties dialog ?  Alternatively have you tried the HATCHEDIT command ?
