Flowmeter typical metering runs.
Does anybody have tables or a link to tables that show the recommended upstream/downstream straight run pipe diameters for each type of flowmeter ?
(I was referenced API 14.3 part 2 but, don't have it)
Many thanks.
Many thanks.
RE: Flowmeter typical metering runs.
Other considerations include flow conditioners, accuracy required (you can give up upstream/downstream if you can live with lower accuracty).
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
My motto on measurement is: There is no such thing as a custody transfer meter, just put in the correct meter, do not argue about accuracy, if you don't care about accuracy, just tap a 90 bend and read the DP and calibrate the reading to some other measurement in the system.
