ASME BPV Codes
ASME BPV Codes
ASME BPV Codes
In a jam,  Full code is on the way.  Does anyone have information relating to ASME B & PV Section IX article II.  I need to get the coupon sizes for qualifying Al-Br inlay with 8630, 4140, and 174-PH.
JBK
RE: ASME BPV Codes
Not exactly sure what you are asking or doing based on your post. What is the specific application - what is being overlayed with weld, or what is being welded or what?????
