Problem with drawing printouts
My drawing contains a number of lines with different thicknesses(weights) but when i print it out i am getting lines with same thickness (Its making thicker lines to thinner). Is there any setting in solidworks options to get thicker lines in printouts (either hard copy or pdf file). It doesn't even show thicker lines in print preview too. Any idea whats going wrong here?
thanks,
nodaldof
thanks,
nodaldof
RE: Problem with drawing printouts
nodal
Do you have the correct line thicknesses set in Tools > Options > Document Properties > Line Font?
Have you tried updating the printer drivers?
Are you using the latest SP5.1 for SW06?
Maybe post the separate drawing here for others to try with different printers. See FAQ559-1177: How Do I Make Files Available For Download? ... No Emails Required
Thanks for your help.
Nodal
