Connecting points of Buildings
I'm hoping you can help. I have a building modelled with a movement joint running through it, so essentially it's two separate buildings. We're looking at ways to connecting the two to provide a shear connection to shore up one of the buildings when they move side-by-side. However it will still allow movements "away" from each other.
It is possible to model the building points along the connected face in such as manner as to account for these effects?
Thank you.
Thank you.
RE: Connecting points of Buildings
I have not had much experience with this myself but I dare to suggest that would need to use some sort of "link" element at the points where the buildings are joined. Also I believe if you use a link system you need to carry out a non linear analysis. Maybe some one else would have a better/simpler way of achieving what you require or could elaborate on the above suggestion.
thanks
How about pounding each other? Did you consider that?
Is it for thermal expansion only?
Just see, if possible by external restraint at those points?
I understand that you are trying to use shear walls along this plane to resist the shear from both the buildings
Is it correct
Cheers
