Assembly Questions
Assembly Questions
I am doing an assembly and I just came across a question.
If I am constraining a pin in a hole, how come I do an axis to axis, and face to face and it tells me fully constrained. Rotation constraint is left. It wont let me move the the item around the last degree of freedom.
Any recommendations?
RE: Assembly Questions
Or, right click, and select "new constraint", and it'll let you add it.
David
However I think you might be connecting through mechanisms where all joints are allowed to move. If that is the case then you have the part fully constrained after aligning the axis and faces. If you want to control the rotation, go to the Applications\Mechanisms and then in your left hand menu scroll down to connections and you can further constrain it there.
C
