PDM Revision Question
I have PDM set up to control the revision block on my drawing. I need to add a rev triangle to my drawing. The only chance I get to add the next revision, is during check-in. If I add a rev triangle to the drawing after check-in, my vault version will no longer be the latest. What shall I do? I'm thinking I'll have to make manual edits to the revision block & just let PDM do the rest. Any other ideas?
Windows XP / Microsoft Wireless Optical Mouse 5000
SolidWorks 2007 SP2.2 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
"Right-click... It's friggin' magic!" ... Jack L. Tate
FAQ376
RE: PDM Revision Question
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
That's essentialy 2 check-ins... right...?
Lava Lamp
www.Tate3d.com
FAQ376
Lava Lamp
www.Tate3d.com
FAQ376
Yes, it may be two check-ins. But your files should be checked-in as you make major changes to your work anyway.
Chris
AutoCAD 06
Lava Lamp
www.Tate3d.com
FAQ376
For me, zones work well to identify the location of the change. Rev ID's all over the drawing are reduntant to zones in my current enviroment. I can see how Rev ID's might be necessary on very complex and highly detailed parts, though.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
So you indicate the "zone" in the revision comment then?
Lava Lamp
www.Tate3d.com
FAQ376
My boss told me that we did have one vendor recently request revision clouds, and i was like "I'm not going to put cartoons on my drawings." lol This is especially true since our models drive the specifications for the parts in question. However, on the model, we do change the color of the feature being modified.
Matt
Silicon Valley, CA
sw.fcsuper.com
I still use triangles and
cartoonsclouds when necessary.RE: PDM Revision Question
Splines for clouds... just curious?
Lava Lamp
www.Tate3d.com
FAQ376
I've also used a clip art cloud copy/pasted from Word.
Lava Lamp
www.Tate3d.com
FAQ376
When a drawing has any change, the whole dwg should be checked for errors ... not just the change. Things change on their own sometimes.
Chris
AutoCAD 06
How does that work when adding subsequent revisions?
Lava Lamp
www.Tate3d.com
FAQ376
Is there a reason why you can't add the revision bubbles prior to check-in? Or are you trying to maintain the revision block link to the revision bubble?
I'll see what I can find in the meantime...I know I've done what you are asking for.
Me no likey...
Lava Lamp
www.Tate3d.com
FAQ376
