---Corrosive and Radioactive Resistant Piping---
I have a recent need to provide piping that is both resistant to corrosives (aqueous solutions of <10% HCL, and <10% HF) as well as have resistance to radioactive materials. We have used stainless steel in the past, but typically it gets "eatin'" within 3 to 4 years. We have tried plastics, but they become brittle due to the radioactivity. Anyone know of a piping material that protect against these? How about a liner, and/or a coating that would protect the piping?
We would like to get protection to at least 6-7 years or double the life of the piping.
thanks,
Carltogr
thanks,
Carltogr
RE: ---Corrosive and Radioactive Resistant Piping---
This is a simplistic approach - to double pipe life from 3-4 years to 6-8 years, double the wall thickness. When we design against corrosion, that is what we do. You can either use better material, or more material. Sort of the "When in doubt, make it stout." method. We get the corrosion rate, and after determineing the life of the pipe required, we get the thickness.
Like I said, this is a simplistic approach.
If you want different material solution, I will defer to my colleagues.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
thread338-185694: Corrosive and Radioactive Resistant Piping
Please do not double post, as that just fagments the responses and comments.
I will move my posting to your other post, as someone has already responded to that.
Albert Einstein
Another possibility is HDPE. Not sure what kind of radiation you are talking about, but HDPE is used as shielding for neutron radiation in nuclear power plants, so presumably it holds up ok. I would check it out further before I went that route though.
