Plating Friction
Plating Friction
This must have been asked before but my search turns nothing up.
what would be the coefficient of friction for a bolted joint when all parts are plated , components, washer, nut & bolt. I usually use 0.2 for the slip between two uncoated steel parts but plated parts seem "slippery" although the zinc coating would probably yield? so the figure may be higher??
RE: Plating Friction
What type zinc coating do you have, hot dipped, electrolytic, or mechanical?
Try this site:-
http://
regards
desertfox
We use electrolytic plating. The bright silver finish.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
