Lines on top of each other when referencing!!!
Hi all,
I am new to the Microstation game and it's been quite an exciting challenge. My current issue has been editing a drawing I've referenced in from another.
Merging the reference into the master for some reason didn't work so I simply just copied the drawing then deleted the link to the reference.
Now I've been able to started editing the drawing but there is the pain of having up to 3 lines on top of each other. For some lines I cannot even change the line pattern and they have to be re-drawn. Is there a simple way to have the whole drawing "flattened" (as in Adobe Photoshop) or is there an easier way to merge everything into the master?
RE: Lines on top of each other when referencing!!!
The problem with copying (and then deleting the copied reference link) is that it left the 3D nature of the elements which made it impossible to use some tools such as "delete partial"
