Pipe Support Spacing Table
I was wondering ids there a typical pipe support spacing table for Sch 5 and Sch 10 Stainless steel.
This is for Air diffuser Application in Water tank.
Any Help would be appreciated.
MiddleMEman
MiddleMEman
RE: Pipe Support Spacing Table
You must be very careful of using pipe hanger spacing tables - THINK first before you specify and consider all the issues. PLEASE read the thread referenced below all the way through because there is a lot of wisdom and experience from a lot of piping engineers here:
thread378-49424: Tables for pipe support spacing
Toward the end of the thread (DON'T RUSH, READ EVERYTHING!!!) you will find a comprhensive aid provided by pipingdesigners.com. Please think about all the issues that are discussed in the thread.
Regards, John.
