Drilled holes in wood lagging
How do I make sure my wood lagging can withstand a few drilled holes (as weep holes). I cant find a good method of analyzing this. Please help.
RE: Drilled holes in wood lagging
A. Lagging is generally not over analyzed, so it is generaly pretty conservative. One or two holes won't effect much. Often lagging has utlity penetrations in unforseen locations, which generally does not cause a problem. Probably would be good to keep holes & penetrations out of the middle third if possible.
B. Since lagging is only stacked, it is generally self draining. Some locations, straw is suffed between the boards to prevent migration of fines. Generally weep holes are not needed in lagging.
