read number in if sentences
Hallo everybody,
I have this file:
parameter=5
Read(1,*)a
If (a==(parameter))
read(1,*)b
write(2,*)b
end if
where parameter it will be used for differents cases but the problem is that seems to be: If (a==(parameter)).It seems that can not read the number that I give two lines before.
Albert
I have this file:
parameter=5
Read(1,*)a
If (a==(parameter))
read(1,*)b
write(2,*)b
end if
Albert
RE: read number in if sentences
two equal signs "==" for that purpose.
if I put a number is working:
parameter=5
Read(1,*)a
If (a==(5))
read(1,*)b
write(2,*)b
end if
but not if I put:
If (a==(parameter))
Also 5 on its own is considered to be an integer, you should use 5.0 for single precision or 5.0D0 for double precision.
It still doesn't work even If I define parameter and a as integer or as real.
If (a==(parameter))
it says "user breakpoint called from code 0x7c901230".
In Fortran, if you don't declare a variable, and it begins with letters a-h, o-z, it is real. Real, real comparisons don't always work.
CODE
integer:: param, a, b
param = 5
read(1,*)a
if (a .eq. param) then
read(1,*)b
write(2,*)b
end if
stop
end
.EQ. rules ok...
Also... the above code now works due to the use of the variable PARAM. The symbol used to check for equality is irrelevant.
Dan
dan@dtware.com
The sky is falling...
"==" in FORTRAN.
Doomed, I tell ye, doomed.
