Material Properties for SA-212 Gr B FBX Needed
I am trying to perform some code alterations to a 1963 code vessel and need the properties of SA-212 Gr B FBX.  Does anyone have a old copy of the code properties?  I am using the software package Compress for the calcs and I need the Tensile Strength at 70 deg F, 150 deg F and 400 deg F.  It also needs the Minimum Yield Strengths and Min Tensile Strength.
As a side note, is there a resource somewhere where I could find these without having to ask the forum?
