Small label printer with Beijers E1000 series HMI
Does anyone have any experience of using a small label printer with a Beijers E1000 Series HMI. I haven't decided on a particular model of printer as I am not sure which will be the easiest to interface to the HMI.
The HMI seems to support Hewlett Packard and Epson and something called 'standard text' (i'm not sure what that means). The page setups seem to refer to larger paper sizes such as A4, B5 etc. I only need to print a few lines of text to a label that would be approx 40mmx25mm. A standard inkjet seems overkill for this, and will take up too much space.
Can anyone suggest a way forward?
Thanks in advance.
