2 position model
2 position model
2 position model
I am using wildfire 2 and I want to model a part in two positions,flat and curved ,so that when I send the model to my customer,he has a choice of opening the model in either position.Does anyone know what I have to do to get this done?Thank you
RE: 2 position model
Is this a sheetmetal part?
It is a plastic part.I want it to show two state;flat and flexed.
Familly tables...
Start with the flat part as the generic, then create a family table and apply the curve and switch it off in the instance.
Your customer can then open the single file and have either part open...or both...whatever!
Hydromech
Heckler asked you if it is a sheet metal because you can convert the part into a sheetmetal IF your part has the same thickness. Then you have the option to show as flat and flexed.
-Hora
Hora is correct that is where my thought was going.  I did a ring tong that way.  I modeled flat and then added a bend.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
