adding fillets in profile
Whilst in sketch mode I have been told that when you are using the profile command you can add fillets to the profile without coming out of the command. How is this done?
Thanks - Kevin
Thanks - Kevin
RE: adding fillets in profile
Now draw straight line.
Now click end point of line with left mouse button and release
Now when you move mouse you will see tangent curve to line.
Nev
I normally hold the right-button down while I move the cursor off the last end point, and that makes an arc.
Or just click on the Line, Tangent Arc, or 3-Point Arc icon in the Sketch toobar.
