7Sj62--7SA611 Fault Records
I have siemens 7SA62 and 7SA611 for distance and overcurrent protection purposes in my substation. Sometimes I got "Power System Failure xx" message, xx is a number specifiying the real couse of the event. Is there a complete list where i can quick find the hitch by looking at the fault number, or should i connect to the device and anlyse the record anytime a "power system fault xx" record dropped.
RE: 7Sj62--7SA611 Fault Records
Anyway you can download Manual for 7SA61, as for any Syprotec relays from here:
h
Good luck!
It may be like this in theory and practice, but in real life it is completely different.
The favourite sentence of my army sergeant
Most of the faults are from 50(N)/51(N), that is due to surface flashover. Substation is in a dusty environment. To overcome the problem, si-coat 570 is planning to be applied.
Does anybody used si-coat 570, or any other coatings. what are the comments?
thanx.
