Help selecting appropriate washer material
Dear Friends,
I'm looking for a specific material for washer (0.25mm thick). The washer should be conductive. The washer will be rotating over annealed 302 SS housing, 0.25mm thick.
Please suggest which materials/plating I should consider for minimum wear of the washer.
Thanks.
Best regards,
ag22
Thanks.
Best regards,
ag22
RE: Help selecting appropriate washer material
Why should the washer rotate?
Or that is only when fastening the nut?
You are not concerned with wearing of the casing?
Please explain.
http://www.welding-advisers.com/
