Makind Sub-Assemblies stand out in drawings?
I have a complicated assembly. I would like to make a drawing of a sub assembly, and have it stand out. It would be good if I could make the overall assembly transparent and the subassembly opaque or something in the drawing.
Anyone have an idea of how to do this?
RE: Makind Sub-Assemblies stand out in drawings?
David
I'm using the latest release and we should be installing 2008 soon.
David
Thanks. I've made progress based on your suggestion, but the phantom lines are way too thick. I thought the phantom lines must be on their own layer and that I could adjust their line weight, but it appears that they are on the same layer as the lines I want to stand out.
I can get the desired effect if I go through and select line by line and change the weights, but that would take all day. Any further suggestions would be appreciated.
Thanks.
