Help selecting conductive and wear resistance bearing material
Dear Friends,
I'm looking for a specific material for washer (0.25mm thick). The washer should be conductive. The washer will be rotating over annealed 302 SS housing, 0.25mm thick.
Please suggest which materials/plating I should consider for minimum wear of the washer.
Thanks.
Best regards,
ag22
RE: Help selecting conductive and wear resistance bearing material
Whoa!!  You be posting this in the wrong forum! This is a communications forum!  You need a materials.
Keith Cress
