Sources of fire
Sources of fire
Sources of fire
Hi guys,
I am checking the calculation of the PSV for the Electrical Seal Heater.
In calculation stated that the sources of fire being confirmed.
What should I consider as a credible source of fire ?
RE: Sources of fire
Quote (VugarN):
What should I consider as a credible source of fire?
Anything that would lead to a "pool fire" in the same area or in an area adjacent to Electrical Seal Heater.  We consider a liquid that is below it's flashpoint and more combustible/flammable than an NFPA Class IIIB to have risk of a pool fire.  So, a pipeline that runs through the areas, a tank in the areas, a pump in the areas, etc.
Good luck,
Latexman
RE: Sources of fire
Thanks a lot!
RE: Sources of fire
In some old buildings, the building itself may be a source of fire (made of wood).
Typcially, during the design, the original engineer will state fire case, and give source(s) of fire.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
