wood fram design
wood fram design
hi, i was just hired by a structural engineering firm for an entry level civil engineer. i am expecting to have to design wood frame houses, 2-3 stories, and would like to get a head start. are there any online links that give you the general idea on how to design using wood? or step by step design guide ?
thank you,
Kit
thank you,
Kit
RE: wood fram design
APA
You will also want to know how to apply wind loads to the structure, so get a hold of an ASCE 7-02 code and have at the wind chapter. For snow loads on the roof, including drift design, also see ASCE 7-02. Same goes for seismic.
When you get to engineered panels (plywood, OSB, etc) then also ADD www.apawood.com and get a free registration and print out their applicable tech bulletins. Off the top of my head from APA you'll definitely want to take a look at "The Engineered Wood Construction Guide", "how to design a squeak free floor system", and "Roof panel attachement guide". I've found that neither Breyer nor the NDS does a great job of explaining practical aspects of the engineered panel stuff. APA also has a few good publications on wall construction details etc you should look at eventually.
Stick to Breyer and the NDS for Gluelam and LVL design. Learn the nomenclature and how to design them from scratch before using manufacturer design tables. www.ilevel.com is where to go for LVL's tables.
Also a must, once you get a handle on design procedures, go to http://www.strongtie.com and order their free main catalog, high wind catalog, and for kicks their anchoring catalog. Not sure how familiar you are with Simpson Strong Tie products, but you need to be. They also put on free full day seminars which I think were actually beneficial to attend as they discuss many different issues associated with load path.
Pre engineered wood trusses are common in some regions for floor and roof members. go to http://www.sbcindustry.com/index.php and get a free registration and have at their FAQ's and publications.
Hope this helps.
The major problem you will run into is determining the amount of structural design you need to do and for what portion of the framing you should just follow the conventional framing provisions of the building code.
For example I probably can tell you in a half an hour how people are constructing three story apartments. It probably would take me two weeks to design one.
For example the use of double top plates is common for the top of the stud walls at each floor level. With the use of floor and roof trusses, I've seen many cases where a double plate would not carry the required loads even if full composite action existed for the plates acting togther as one unit.
As a entry level person, a lot of what you will need to do, will be based on the requirements of the engineer who is signing the plans. I would reccomend that you look over the conventional framing provisions from some of the building codes, then chat with your supervisor about what aspects of the houses he or she wants an exact design for.
http://www.awc.org/pdf/WCD1-300.pdf
They also have a good list of free downloads.
