Gm DCS toolkit
Gm DCS toolkit
Does anyone have any information on where to purchase the GM(DCS) toolkit, and a price. Our company is looking to buy this for a current GM Defiance Plant job. I have called UG support and the GM helpdesk and have had no luck. It is my understanding that the toolkit validates the Cad models to GM's standards,catagories, etc.. Any information would be great.
P.S. We Currently Run NX2,3,&4
Thanks in Advance!
Thanks in Advance!
RE: Gm DCS toolkit
You need to get your company registered at gmsupplypower.com in order to get all the information you'll need. I would recommend that you get with your superior and discuss this before diving in blindly. The registration can affect your entire company and isn't anything like signing up for a news bulletin. It affects all aspects of your company business with GM and an administrator will need to be chosen for your company.
Once you sign up, look for the Engineering area and you'll want to find anything related to Blockpoint (this is the stupid GM name for updating software or migrating). I suppose update or migration is a term that's too simple and easily understood to use.
I would strongly recommend outsourcing the GM portion of the modeling/drafting unless you're dealing with large numbers of NX parts on a daily or weekly basis. We were able to have a single part and drawing submitted to GM for $55.00 and that covered up to 10 hours worth of work in NX. If you're going to be working on just a few GM programs each year, then this is definitely the way to go. It's much simpler to just let someone else do it than try to teach yourself and/or get into a training class, not to mention the expenses.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
RE: Gm DCS toolkit
RE: Gm DCS toolkit
I'd get a few quotes, talk with each vendor and then decide based on price mainly.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: Gm DCS toolkit
As for the cost and where to buy I'm not sure other then contact UGS and see if they are the seller of this toolkit for GM. If not contact your GM project manager/contact and they should be able to route you to the appropriate channels.
The Teamcenter link to GM is not always a requirement. It depends on what center you are submitting work to. Some require you go through a Tier 1 supplier where others allow you to submit native GM/PDL Compliant data to and they will import into the GM Teamcenter.
A lot of variables to think about. The GM PDL is a good set of applications regardless if it is a requirement to have. I personally would get it just for the Inquire application to clean up the files.
-Dave
http://plmwiki.com
http://groups.google.com/group/NX_CAX/
RE: Gm DCS toolkit
Supplier Communication Day
May 14,2007
Author : GEES Service Desk
On behalf of the GM Global Extended Enterprise Services (GEES) team.
Introduction of Check-Mate at GM
To improve Math Data Quality at GM, Check-Mate will be replacing the current GM/PDL DCS FileChecker as the Global checking tool. Projected deployment date for Check-Mate is August 2007 at all Global GM Engineering Sites.
This invitation is for all Suppliers that create math data for use at GM.
Dates/Time: Day 1 05/18/07 12:30pm-2:00pm (VPPS 10-40 preferred)
Day 2 06/15/07 12:30pm-2:00pm (VPPS 50-80 preferred)
Please see the notification posted in "Application Change Management"
Engineering Libraray>Global>GEES Operations>Application Change Management>934-Check-Mate's Supplier Communication Day
h
Please direct all questions regarding this message to the GEES Global Service Desk at 1-888-238-1119, or send an email to geescallcenter@eds.com.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
