How to move a hole callout?
Does anyone know of a way to move a hole callout from the original hole, to an instance in a hole pattern?
RE: How to move a hole callout?
The Hole Callout gets attached to the seed hole of the hole pattern, so you will need to edit the pattern feature to move the seed hole to the required position.
The pattern type used determines how the seed hole can be re-located.
cheers
SW07-SP3.1
SW06-SP5.1
Thanks CorBlimey.
Last night I found I could add an extra leader to the callout with a ctrl drag. It seems a shame that the original leader can't then be deleted without, deleting the callout.
