wheel rate vs ball joint rate
A few of the internet calculators spit out BJ rate, but I'm assuming this is not the same as wheel rate if the center of the contact patch is not under the BJ. Do I just re-calculate the motion ratio from the wheel center?
RE: wheel rate vs ball joint rate
Norm
Formula and image is going with it.
Goran Malmberg
