How to calculate the capacity for the typical tilt-up wall-to-wall con
I need to find out the shear capacity for the typical tilt-up wall-to-wall connection.
In this connection, steel angles are embedded at the interior face of the wall panels with two inclined headed stud welded to each angle. A steel plate is welded to both embedments to form the connection.
I am NOT quite sure about how to use the equation in ACI-318-02 Appendix D to get the capacity for this connection.
Anybody know how to calculate the capacity for this connection? Many thinks!
RE: How to calculate the capacity for the typical tilt-up wall-to-wall con
