Edge Loading of Concrete Wall
Hello, I have an 8" stem wall which is notched out at the top 2-1/2" for joist framing. The PROBLEM is that I have a steel beam that is sitting on that 2-1/2" edge and I am not sure how to calculate the capacity of that bearing connection before you have some kind of shear slip failure toward the free face of the wall 2-1/2" in from the end of the beam.
I thought there would be some kind of shear equation analogous to "punching shear" or "shear slip" that would tell me how much I could load the 2-1/2" edge with my steel beam before a crack formed at some angle inward toward the inner face of the wall. This doesn't seem to match up though with the typical punching shear model with an outward shear path from the point load.
Is it really concrete in bearing that dictates my capacity??? What's the best way to go about this design???
RE: Edge Loading of Concrete Wall
