MITERED ELBOWS EXTERNAL PRESS. DESIGN
ASTM B31.3 ON PARA.- 304.2.4 .- THE WALL THGICKNESS OF CURVED AND MITERED SEGMENTS OF PIPE SUBJECTED TO EXTERNAL PRESSURE MAY BE DETERMINED IN PARA.- 304.1.3
THE QUESTION IS ON A MITERED ELBOW WE CAN USE L THE DISTANCE OF EACH MITER SECTION ????
IF THE l IS OK TO HAVE THE PRESSURE REQUERIDDED WE NEED TO REVIEW THIS UNION WITH REINFORZEMENTS ??
RE: MITERED ELBOWS EXTERNAL PRESS. DESIGN
prex
http://www.xcalcs.com : Online tools for structural design
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
Do you mean that L is the distance on center line of each of the miter or is the distance of the center of the elbow to each of the termination.
thanks
In other words: take the full center line length of your elbow and treat it as a straight piece of pipe.
prex
