Dynamic Blocks and Look up tables
I am making new blocks of through bolts and have the list set for the bolt length in a lookup table BUT on the stretch for the nut and washers it has a min. of 0 but I am looking to set the max for each of the bolt lengths. This is also added to the same lookup table and it will not work.
According to the Autocad 2006 help information
to Specify Values for Lookup Tables , one of the rules is
"For a continuous range, use a pair of values separated by a comma, enclosed in brackets or parentheses. For example: [3,10] specifies any value between 3 and 10, including 3 and 10 (3,10) specifies any value between 3 and 10, not including 3 and 10. "
Has anyone done anything like this and gotten this to work?
If so how?
David
If so how?
David
