Jet Tech (Siemens) tank mixing system
Hi all,
Has anyone worked with tank mixing system from Jet Tech (was under USFilters and now under Siemens)?  I am trying to determine if it is as good as the Rotamix jet sytem. We currently use Flygt mixers in wash water EQ basins (>0.01% solids), sludge EQ basin (>0.35% solids) and sludge holding tanks (up to 4% solids) in a water treatment plant. However those mixers (propeller type) keep failing every 6 months or so.
Daamz
