Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I really enjoy your site. You have a lot of helpful and friendly experts who contribute so willingly. Thank you for past (and future) technical advice..."
Geography
8060A (Industrial)
25 Apr 07 17:47
I'm designing a device with two LED annunciators that must be NVIS A compatible. This device is not in a cockpit and does not require intensity matching. Does anyone know which frequency of LED best meets the requirement. A GAP LED is 555nm, which I think is ideal. However, these are dim by todays standards. There are new chemistries in the 528nm range. What I don't know is if this is acceptable for NVIS A.
IRstuff (Aerospace)
25 Apr 07 19:21
4th hit from dogpile search for "nvis a" spectral:
http://www.gamma-sci.com/PDFs/ANVIS.pdf
TTFN
Helpful Member!  wktaylor (Aeronautics)
1 May 07 13:03
8060A... following may be useful...
SAE ARP4168 Night Vision Goggle (NVG) Compatible Light Sources
Regards, Wil Taylor
FLYHMDS (Aerospace)
27 May 07 16:48
Most, if not all, LEDs emit in the short wave IR  (SWIR) band (700-1000nm) in sufficient intensity to make your device non-compliant.  NVGs have incredible gain, so even though the manufacturer's spectral plot shows negligible to no emission in the IR, the LED probably emits.  Even Blue LEDs will be visible to NVGs due to their IR emission.  Few manfacturers will provide LED spectral plots with a log scale.  With this type of plot you can see if the LED emits in the SWIR band.
The only sure way to make an LED NVIS compliant is to filter it.
MIL-L-87562 provides the maximum emission requirements for NVIS compatible illumination.
Close Box
Join Eng-Tips® Today!
Join Us             Close
