modeling a spring along 3d axis
I am looking for an updated version of a process to create a coil spring along the path of a 3D curve. (a spring over a piece of nylon tubing). I have a process written for Pro/E version 21. I'm sure there must be an easier way now,
Any ideas? Thanks
RE: modeling a spring along 3d axis
Thanks, cadcamguy, that's what I was looking for!. The procedure I have is much older, this should do the trick!!
