SUB-ASSEMBLY SHUFFLE
Read this  v e r y   s l o w l y ...
I had an assembly containing 2 sub-assemblies. One of thos sub-assemblies contained a sub-sub-assembly. I dragged the sub-sub-assembly out of the sub-assembly. Now I have an assembly containing 3 sub-assemblies.
But in order to drag the sub-sub-assembly out of the sub-assembly - I had to insert a random part in my assembly (at the bottom of the "tree")... so I could drag the sub-sub-assembly out, & drop it below that random part. Then I deleted the random part.
Holding the ALT key down to re-arrange components in an assembly don't woork so good when all the components are sub-assemblies.
Anybody have a better way to do what I did?
Windows XP / Microsoft Wireless Optical Mouse 5000
SolidWorks 2007 SP2.2 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
"Right-click... It's friggin' magic!" ... Jack L. Tate
FAQ376
RE: SUB-ASSEMBLY SHUFFLE
Could you not have had the main assembly open as well as the sub-assembly containing the sub-sub-assembly and then dragged the sub-sub-assembly into the main assembly?
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Would that have worked... or would it copy the sub-assembly?
And then I would have to re-mate everything... right?
Lava Lamp
www.Tate3d.com
FAQ376
I was thinking that, when you dragged the sub-sub-assembly out, it would have made another copy. I guess that'll teach me to assume.
My way would have required you to create new mates...
Jeff Mirisola, CSWP
CAD Administrator
I read your post several times. I don't understand why you moved around the subassy's.
Was it just to reorder them in the main assy?
The easiest way would be to undo some of the mates to reorder. A part or subassy can not be reordered before a part or subassy it is mated to.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Try "Tools/"Reorganize Components"....then you can select the sub assembly to move, then select the destination assy.
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP3.1 on WinXP SP2
Thanks Gilda...
That worked just swell.
Lava Lamp
www.Tate3d.com
FAQ376
Another star for you Gildashard.  I have run into this situation in the past.  Fortunately I wasn't working with an assembly containing only subassys.  So I didn't have to create a dummy part.
-Shaggy
I tried this without the tool I recommended earlier and it works for me, unless I'm misunderstanding. I created a assy containg two sub-assemblies, the two sub-assys contained additional sub-assys. I then dragged the sub-sub-assy into the top level. I just dragged it over the top level sub-assy which gives you the "double arrow" icon and it moved it into the top level fine. Did I miss something?
Jason
The problem sometimes arises when dropping a component or sub-assy below a sub-assy. The Alt button doesn't always switch the drop from "Add to" to "Add below".
cheers
SW07-SP3.1
SW06-SP5.1
Well... shave my head & call me Curly... it worked!
I never dragged it to the top of my feature tree the first time thru.
Lava Lamp
www.Tate3d.com
FAQ376
