Need to get an RS-485 and RS-232 from a single RS-232
Hello everyone, i need to know if it is possible to get an RS232 port and an RS-485 port from a single RS-232 port. I know it is possible to change an RS-232 to an RS-422 or 485, but what i need is to have two usable and independent ports from a single port. Does anybody know if this is possible? i hope somebody can help out with this issue.
RE: Need to get an RS-485 and RS-232 from a single RS-232
RS-232 port >
> 232/485 converter
>485 multidrop port
>485 multidrop port
> 485/232 converter = 2nd RS-232 port
Almost by definition, no. Given that common sense answer, almost anything is possible if you're willing to hack enough.
One could even imagine an external box (custom design) to do exactly what you want (within the speed limits of the existing circuit).
Converting standards is easy.
www.blackbox.com
Making two from one is the tricky bit.
danw2 (Industrial), i didn´t understant what you ment with that, was it that there is a device that turns one RS-232 in two RS-485? that would work just fine!!! do you know where one of such devices can be bought? if you do, please let me know.
Dan - Owner
http://www.Hi-TecDesigns.com
You will have to use the 232 ports as if they are 485 ports by using some sort of device addressing scheme. a 232 serial communications protocol that doesn't include an addressing scheme won't work on a multi-drop buss.
B&B Electronics makes all kinds of serial converters.
MAX3160, MAX3161, MAX3162
+3.0V to +5.5V, 1µA, RS-232/RS-485/422 Multiprotocol Transceivers
"Convert the 232 port to 485. Once you have 485 you can add 32 devices to the 485 buss. So, add a 485 to 232 converter to get a 232 port."
what I tried to convey in another fashion.
One comment on the addressing:
"You will have to use the 232 ports as if they are 485 ports by using some sort of device addressing scheme. a 232 serial communications protocol that doesn't include an addressing scheme won't work on a multi-drop buss."
One could have a multidrop topology of listeners only, (no response, no talkers) where addressing wouldn't be needed, ala AM radio broadcast over the internet.
The 485 circuit essentially 'broadcasts' whatever the source RS-232 port transmits. That might work, depending on what the OP is trying to achieve.
It isn't even clear whether the 485 is needed for multidrop or for distance.
Or clear whether this is a circuit design or implementation where only one 232 port is avialable, but 2 devices need to hear the source. Or an attempt at working around the point-to-ponit limitations of RS-232 . . .
Dan
Another friend addressed an electronic scale and an electronic syringe drive, both from the (single) serial port of his Mac, at two different baud rates with no addressing. There were some code collisions with single character commands for one device being received and acted on by the other device, but only for a set of commands he didn't need for the application.
Sometimes you're better off not knowing any better...
Mike Halloran
Pembroke Pines, FL, USA
Yes, it could be possible to communicate on a RS485 network without addressing but it makes life tougher.
Now, the origional post asked for independant ports and I'm still not sure any of this satifies that requirement. You can't make 2 completely independant RS232 ports out of one.
